My car is a 1963 Dodge Polara 440. It is an original race car, with only 7,700 original miles. I did not build the car, but I did build the current engine.
It was mini-tubbed some time in the early to mid 60's, based on the info that I received from the seller. I am the 3rd owner.
When I bought the car, it had a stroker motor based on a 400, with somewhere around 13.0 to 1 compression. It also had a 4.88 full spool and a super high stall speed. It was a 10 second car, but definitely NOT streetable.
When the engine spun a bearing, I built a 1969 440, 30 over with 11 to 1 compression. I changed the TC to a more streetable 2800 stall and I removed the spool and replaced it with 3.91 sure trac in a 489 case.
The car was originally yellow, and was purchased in NC by a race team from Ohio. The current bodywork and paint job was completed in 1989 by the 2nd owner. I would love to redo the car again, with the tubs and cage up to current specs and technology, but I am also hesitant, because it's so nostalgic. There are still class win stickers in the window from 1964.
Unfortunately, I don't drive as much as I want to, it mostly just sits in my shop. My 440 Power Wagon gets way more attention.
