ThanksLooks good.
I’ve got my shifter in the furthest back position. So I don’t know about using any stock plates. Might have to fab one.i cut the center bar out so i should be able to have all the movement needed if not ill cut all the chrome trim out of the middle to see if I can match it up to the 4 speed top plate or ill just buy a 4 speed top plate lol
i just moved the console so the shifter is centered in the top plate , my shifter is in the rear position as well and the tr6060 shifter rear position sits further back than a t56 magnumI’ve got my shifter in the furthest back position. So I don’t know about using any stock plates. Might have to fab one.
just made some , it was easy enoughDid you use repop brackets or make some?
radius the console? mine sits up a little so its not actually touching , enough to get carpet underThat lines up nice. Are toying to have to radius the front at all due to your new tunnel? I’ll have to clearance mine some.
