- 11:46 PM
- Feb 22, 2021
- Roswell, New Mexico
Since this is my first attempt at building
Ma Mopars biggest, I'm very unfamiliar
with the way this big hunk of Iron is
supposed to sound. I've run a compression
test (dry/cold-5 revolutions) and all 8
register 150 psi on the dot. 40 psi oil
pressure cold at start, drops to 35 psi
warmed up. I'm getting (what I perceive
to be excessive valve train clatter). The
pressures exiting the pipes are smooth
and even with no pops or misses.
I would assume since there are no
engine stumbles, and compression is even
that the pushrods/lifters a functioning
normally. I do have a taller set of aluminum
valve covers installed to head off future
mods. Could it be they are just amplifying
the valve train noise?
