themechanic
Oklahoma is OK
- 3:40 AM
- Nov 11, 2012
- Moore, Oklahoma
My 69 Coronet R/T has been at my daughter and son-in-law's (Jeff) since Rusty, Uncle Bill's 70 Cuda, came home to me for a thorough going through about a year and a half ago. Jeff seldom drives the Coronet. When he does, he just goes for gas and back.
Friday, Jeff calls telling me he drove to the gas station about 1/4 mile away, filled up and on the way home heard a noise under the hood. I went up there yesterday and started the car. No noise. We drove around a few blocks then I heard a knock that increased with rpm. I popped the hood and listened and think I heard a slight knock on the driver's side. I started back to Jeff's house and the engine stalled then wouldn't crank. We managed to tow it back and parked it in their garage.
Before starting I pulled the dipstick and saw dark oil but could still see through it to the dipstick. I wiped it off and checked again. It didn't feel dirty but was slick and no smell of gas in the oil. This time the oil looked almost new; Brad Penn oil is kinda greenish.
I don't know the history of the rebuilt 440. I was told it was a rebuilt RV 440. I did see cross hatching in the cylinder bores when I pulled the oil pan to fix a leak a while ago. The tops of the heads looked clean when I replaced the valve cover gaskets. I use Brad Penn 10W-40 oil and change the oil and filter yearly. I don't drive the car much, probably less than 300 miles since I bought it in 2012. So, I always crank the engine until I see at least 20 psi oil pressure before pumping the gas and starting. I explained that procedure to Jeff but I don't know whether he followed it. The temperature never gets over 200 on 100 degree days.
I plan on swapping cars again when Rusty is back on the road so I can pull the engine at my house. I'll either buy a crate engine or take mine to a machine shop in town for a teardown and rebuild.
My guess is the rebuild to stock would be the least expensive route. I don't want or need 500 horsepower. I just want a good, reliable driver.
I just thought I'd let you know about my misfortune. At least I was the one driving and we were only a few blocks from home.
