Gary P
- 1:45 AM
- Aug 21, 2019
- Pleasant Grove, Utah
I am not sure what you’re describing with the juddering term. Can you help me with that. Is it jumping, running higher like neutral between shifts or something like that?? The original clunky linkage did the same thing which is to move that trans lever along with the throttle moving to control shifts.
Ill do my best -
I don't think the juddering is a transmission thing - it's happening too fast for it to be the trans going in and out of first, or neutral between shifts like you said. It's not lurching, more a vibration and no power. Only did it one time on each drive, but it feels like a misfire, because up at 2500rpm it clears and she goes again. That's why I wondered if it's a timing thing.
BUT - I guess it could be a fuel delivery thing too. I have my head buried in Mopar forums again.
Dirt in the jets - unlikely, I've been very cautious with the new carb.
Fuel pump going out - maybe, but don't they just stop altogether, instead of coming and going?
Fuel Filter clogged - possibly, and the clog is too much for the fuel that the carb demands when I romp on the gas pedal?
