Are you going to run a Mellonized oil/dist drive gear rather than a bronze one?
Those specs are real real close to what’s in my 505. I installed mine at 108.
110 C/L installed height is what the card spec’d. V/P clearance was too close for my comfort though.what was the installed C/L of your cam straight up? Did you install for more low end?
No I lowered it.So in theory you move the powerband UP in the RPM range a bit, correct?
Well, I'm getting great pricing from him, but I may find I'd rather pay more than wait, but the "wait" isn't specified, and he's my builder that I don't want to lose, so it's more "complicated" than I thought it would be.440 Source has 270’s in stock. Have had for a long while. If you’re currently waiting on a set from someone else, you’re missing the boat. They stock the “hydraulic roller” version, but the only difference in any of them is the springs.
He has also been working within parameters I discussed with him from the beginning, that I wanted to start the collection of parts for my build with the Bill Mitchell RB block, and go from there as my budget would allow.It is really important to have a builder you trust.
Get some Superformance gaskets, max wedge, they are accurate size & the best gaskets ever, Hughes sells them , you will thank me laterStill in Machine Shop Jail, and getting more nervous about the situation by the day.
Making progress where I can though. Got my transmission blanket fitted this weekend; had to re-route my cooler lines to do so which is all -6 braided hose and AN fittings. I’ve had this blanket for a while, but just now getting it installed feels like good progress.
Also getting started on port-matching my Indy intake to the heads. Will be cleaning up the plenum as well, more pics to come as this job unfolds.
Below is a look at the 270 port against what is a max-wedge gasket. I can only assume that the gasket is pretty close to an actual MW port. So the 270 is slightly shorter, but with todays technology, I bet it outflows a factory MW port by a ways.
Superformance gasket and regular Max wedge comparsionGet some Superformance gaskets, max wedge, they are accurate size & the best gaskets ever, Hughes sells them , you will thank me later![]()
