More stuff…
The new pan showed up today. No regrets, even though it was an extra expense I hadn’t planned for. I’m pretty sure it is the same part number as the orange pan, but it’s evolved over the past 20+ years. The notch in the sump provides an inch more clearance for the steering center link. I think the revised drain plug location is also an improvement. It looks damn good in silver (zinc) but it will end up being HP Orange like the rest of the motor.
While looking for the other valley pan end plate, I stumbled across the original trans dust shield that got damaged because it wasn’t compatible with the new, smaller than stock 10” bolt pattern on the converter. I ended up cutting the damaged portion off so it can go back on the car. I still need to clean up the edge a bit…
