- 3:55 AM
- Apr 13, 2012
- Granite Bay CA
With the original 23 year old hose back on, I started pouring in anti-freeze.
Why? I should have just put straight water in since I was going to need to replace that lower hose soon. Sometimes my logic fails when I’m pissed or frustrated.
I started it up after dribbling fuel in the carburetor vent. It fired right up and ran fine but there is a water leak. I can’t tell where because of the limited light. A flashlight barely helped. It might be from the water pump. F**k it….
I left out of there in a bad mood, pissed that there wasn’t any obvious problem to solve. I called and ordered a 26” radiator from ECP/ Speed Cooling. I have that radiator in Ginger. It bolts in like stock, uses the stock shroud and hoses too. The radiator may not be the problem in this case but I don’t like the fact that hoses are difficult to find and mounting a shroud means some custom fabricated deal.
At home, I put the thermostat in a pan with water and set it to boil.
It is a 180. It sure looks open to me.
After ordering the radiator, I started feeling better about it all.
I’ll have to change to a 1970 correct water pump housing with the LH lower hose nipple. No problem, I have a few to use.
Which water pump would you use?
It seems to me that the one on the right (GMB) would move water better.
