JR_Charger
I don't think the size of the diff matters. The distance between the leaf springs won't change unless you move the springs in. I wonder what guys who relocate the springs do for sway bars?
I don't know much about the '73-up isolated suspension design, but my '71 Charger has the PST Front and rear sway bars and I like the way it handles. It does not understeer like stock, it seem pretty neutral, to slight oversteer (nice if doing SCCA Solo), but the car has stiffer than stock rear springs and the Mopar 0.960" T-bars too.74 charger 318
Has original front sway bar.
No rear sway bar.
Looking at adding a 3/4” rear bar.
Will that size bar play nicely with the factory front bar?
After measuring, I bought The Helwig bar also, haven't had a chance to install it yet.CKessel went through this. He used a Helwig rear bar that was narrower between the lever arms.
Some stock parts got later the Mopar Performance PN supersedes number. The stock Magnum BB camshaft ( and 6pack camshaft bro ) is one of them in fact, being the first (and second) one on the MP catalog listI found a chart, but looks like part numbers are not factory because they start with a "P".
I'm shopping for a rear bar. I've currently got the QA1 bar in front, which is 1 1/8." I may change to Hotchkis's front bar in the future, does anyone know what size that one is? I'd like to get my "system" right. Firm Feel has a 7/8 rear bar, which may match their 1 1/4 front bar. PST has a 3/4" rear bar. No idea what size the Hotchkis bar is.
I'll be using the 50+ yr old stock springs until I can get the final weight of the car. If the car rides better with factory springs and a rear sway bar, I'd rather do that than stiff springs and no sway bar.
Firm Feel makes new ones, but I don't know if they are any stronger
Why do you want to go to a 1 1/4” from SA?I'm shopping for a rear bar. I've currently got the QA1 bar in front, which is 1 1/8." I may change to Hotchkis's front bar in the future, does anyone know what size that one is? I'd like to get my "system" right. Firm Feel has a 7/8 rear bar, which may match their 1 1/4 front bar. PST has a 3/4" rear bar. No idea what size the Hotchkis bar is.
Firm Feel makes new ones, but I don't know if they are any stronger or not.
OK Gotcha. That’s the main reason I didn’t do a Qa1 K-Frame. I still dont like how the Hotchkis looks going through the Qa1 frame and tying in to the LCA.SA?
The QA1 bar I have has to be mounted under the QA1 k member. No one likes that. Another user was able to mount a Hotchkis bar through his QA1 kmember. The QA1 bar is too wide for that, it hits the strut bars.
Ah, some of the stuff people do on here is overkill, I’m guilty of it myself. My buddy has a Mopar junkyard and I’ve helped him probably jerk out over 15 RB K-frames to sell at the big shows and I have never seen the first one ever cracked. Not saying it doesn’t happen. I mean if you do some type of racing I’m sure modifying them helps but I think it’s overkill in other regards. I may get someone to custom build me a tubular one to my liking. I called Qa1 and told them their tubular K-frame design was over 20 years old and could use some upgrades, especially the SA design. They told me to buy their coil over set up. I told them it’d be a cold day in hell before I ever put a Ford Pinto front end in my car.Well, the QA1 k member doesn't have to be permanent. Modifying the factory k member to the extent some here do is beyond my current skill level. I'm learning to be o.k. with leaving the advanced stuff till later.
I haven't used one (yet) but I have looked at them pretty hard. I think they are a good idea and do what they say they do.Speaking of the steering box, anyone try Firm Feel's Sector Support?
Yes and have it in right now in my car. Have front and rear sway bar as wellSpeaking of the steering box, anyone try Firm Feel's Sector Support?
The K in my 66 Belvedere is 32 lbs with mods and still uses the stock steering box mount and engine mount stands but they are modified. Have another K that's 26 lbs but there's no stock engine mount stands. The engine will have to use Effellant ears with the 26 pounder.Well, the QA1 k member doesn't have to be permanent. Modifying the factory k member to the extent some here do is beyond my current skill level. I'm learning to be o.k. with leaving the advanced stuff till later.
