Thank you for the tip!! I’ll make sure I have a good ground. Yes I used the 69 wood grain…. I like the darker wood. The 70 was to yellow in color.Make sure you clean the paint on your dash where the cluster screws to the dash, otherwise you will have bad grounding, and your gauges will fluctuate. Is that a 69 Woodgrain? 70's are available.
