What did you do to your Mopar today?
installed the new trunk weather strip
New aluminum radiator from Auto City.
Old radiator cut open...
Took her to a car show out here in Germany today. Just a small one with not many Mopars. Saw a beautiful 68 Charger with red tail strip just leaving as I got there. Missed a photo o that, but took a few random ones including my friend Thomas's Dick Landy 68 Coronet R/T.
The Eldorado drop-top gets the horns, ala Boss Hogg and rich "DADDY" on Smokey & the Bandit
Been fighting idle plugs fouling on my crossram. The Holley's I put plug with a .030 restricter in the IFR's but still loaded up. Member stage3 said he used secondaries to add air and closed primary blades. Also he made it so he could adjust secondaries without removing carbs. I bought 8/32 x 3/8" bolts so I could make adjustments with engine running. I closed primaries all the way started it and even idle OK without even warming up. Red arrow is bolt to adjust secondaries.
Home from camp last night. Today draining the ethanol free premium out of the Lund for the cars to mix with my AV100LL 66/33. Charging each cars battery so they're ready to go. All 4 in the shop haven't run since May and why I have zero comprehension of guys cooking batteries with tenders left on 24/7. All 4 batteries came up as 90% and took 5 minutes to hit FULL. 2 Odyssey AGM's and 2 lead acids. Tomorrow or the next day I'll video all 4 cold starting after 4+ months of down time with no carb priming....
After that it will be time to get to work reassembling the Superbird..
As promised.. at least for one car!
Granma got a panic call to pick up our Granddaughter at daycare and the old '64 Dodge 440 was the only one with a car seat in it. Hasn't been started since mid MAY ! Not sure why so many complain that their cars won't start after a few days to a week sitting.... others suggesting that they need an electric pump etc to get the old bastards to start ! I have no issues, and I'll show 4 more in the days to come.
That’s about normal.
It's a 64 dodge will run every time.
