- 12:58 PM
- Aug 29, 2019
- Jarvis, Ontario
I assume that is Barry's engine? Gotta hurry, or Mark will have the body ready first.Assembled the pins on a set of forged 440 slugs.
For those not familiar: The machine below heats up the small end of the rods so the pins can slide in (when at the same temp there is a .001" - .002" press fit). The part that holds the piston allows for an adjustment so that when you press the pin in the rod is exactly centered. It works well but you have to be fast and perfectly aligned or they get stuck!
All done! Now to file fit and install rings.
