- 10:02 PM
- Jul 17, 2008
- South Jersey USA
wow, is that why every Holley I ever ran turned out to be a pos?
There can be vacuum, and fuel leaks internally from the warped main body AND metering block.. which can't be visually noticed outsideExcellent point. Thank you.
There are no vacuum leaks, no fuel leaks but it runs rough and a bit rich too.
Could be.. often the culprit is someone did not use the right PV, or some issue thereof, which does not allow the metering block to sit flush to the body. And then cranked the bowl screws down to " tighten er up!"wow, is that why every Holley I ever ran tuned out to be a pos?
10X.......btw.....in a ' 63 Plymouth Valiant with a stroked 750 inch BB, 727B trans, 250 hp nitrous system, 12.0 pistons, Marvel-Shebler carbs, 7-1/2" 2.73 rear gear and 7.50 x 13" tires....three questions: what oil to use, best cam for street use and most importantly, what's the best wax to use on a bbq black rattle can flat black paint? My buddy said use Rustolium...he also said use BERU spark plugs because they're the best ...just curious.....
Answers above in red10X.......btw.....in a ' 63 Plymouth Valiant with a stroked 750 inch BB, 727B trans, 250 hp nitrous system, 12.0 pistons, Marvel-Shebler carbs, 7-1/2" 2.73 rear gear and 7.50 x 13" tires....three questions: what oil to use, best cam for street use--for these first two, whatever @dvw says--and most importantly, what's the best wax to use on a bbq black rattle can flat black paint?--bacon grease My buddy said use Rustolium...he also said use BERU spark plugs because they're the best ...just curious.....
BOB RENTON
Are those Marvel-Shebler carbs off a tractor? I rebuilt several for tractor restorer buddies. How many are needed to feed 750 Cu In?10X.......btw.....in a ' 63 Plymouth Valiant with a stroked 750 inch BB, 727B trans, 250 hp nitrous system, 12.0 pistons, Marvel-Shebler carbs, 7-1/2" 2.73 rear gear and 7.50 x 13" tires....three questions: what oil to use, best cam for street use and most importantly, what's the best wax to use on a bbq black rattle can flat black paint? My buddy said use Rustolium...he also said use BERU spark plugs because they're the best ...just curious.....
BOB RENTON
At least 8 but possibly 10, but should be an even number.....tight fit on a tunnel ram manifold....but great street performance.....a little touchy to get them all synced...?...Are those Marvel-Shebler carbs off a tractor? I rebuilt several for tractor restorer buddies. How many are needed to feed 750 Cu In?
My buddies 750 ci Hemi has 8 beer can size holes feeding it.Are those Marvel-Shebler carbs off a tractor? I rebuilt several for tractor restorer buddies. How many are needed to feed 750 Cu In?
But what was the most important consideration.....was it a full body laugher, a wheat, an ale.....but hopefully not a tight......how about FAT TIRE?......and only one can?My buddies 750 ci Hemi has 8 beer can size holes feeding it.
BOB RENTON
Always a full body laugher, Bob.But what was the most important consideration.....was it a full body laugher, a wheat, an ale.....but hopefully not a tight......how about FAT TIRE?......and only one can?
BOB RENTON
I pulled the spark plugs to do a compression check. All the plugs were sooty black. Most of the cylinders showed 133-140 psi. The lowest was 130. That is a pretty close spread.I replaced the metering block with a known good spare and the car idles much better and isn't smoking from running rich.
I don't know what was wrong with the other metering block. All the passages were clear. The one in there now has new jets and a new power valve. It doesn't rev up as clean as it should so there is still something amiss inside. The spark plugs are 17 years old. The plug wires are older than that. Remember, this car was pieced together starting in 2007 using a lot of junkyard parts. I did set the timing to 10 degrees BTDC since it has a MP reproduction 340 cam. Back when I first got it running, the dude ran pretty strong.
At least now it will start and run. I can drive it and it won't buck and belch smoke.
It has been awhile since I did a full rebuild on a carburetor. I’ve changed jets, power valves, metering blocks, accelerometer pump cams and such but it has been years since I did a full tear down.
I have these cars out back:
Ive been advised to try a Sonic cleaner and simple Green on my next one. Not as harsh of plated surfaces
great looking white porch railing.....what does it have to do with rebuilding carbs?It has been awhile since I did a full rebuild on a carburetor. I’ve changed jets, power valves, metering blocks, accelerometer pump cams and such but it has been years since I did a full tear down.
They both have mild 360s with the most basic of all Holley carburetors, the 600 4 barrel manual choke, list 1850.
Sort of like this one:
I bought these rebuild kits:
Since it has been awhile, are there any tips or short cuts anyone has to offer?
I'm going to get a can of that Chemtool carb solvent to dunk the parts into and I have a few cans of carb cleaner.
I thought maybe I've missed out on some tips since the last time I did this.
Did you even read what he had posted?great looking white porch railing.....what does it have to do with rebuilding carbs?
BOB RENTON
