Hwy145
Clay bar…
Please explain...Clay bar…
Please explain...
Saw a vid about using one of those cutlery cleaning gizmo's with the brushes inside that cleans both sides of a fork at once. Just slide the belt between the brushes and scrub. Seemed to work well. took a few minutes each belt using liquid cleaner and a clean wet cloth to rinse. My belts in both the truck and the car are really grungy.
No, the trick is to lay a big towel over the seat, pull the belt all of the way out at the top and push the buckle up there and clamp it so it stays there leaving the belt all loose. Then spray the belt with cleaner soaking wet and use the brush. Wipe it off repeatedly with a wet towel till it wipes clean, done, dry with a hair dryer so the wet belt doesn't reel back into the holder and get moldy. You can test if it's clean by comparing the lower end of the belt with the upper end that never gets pulled out.OxiClean did wonders for mine! Maybe the spray version with the two sided brush you showed?
I'm sure you don't want to take them all apart!
View attachment 1717529View attachment 1717530View attachment 1717531View attachment 1717532View attachment 1717533View attachment 1717534View attachment 1717535View attachment 1717536
That’s sad, you trust someone and they do that! Head tech for what, the maintenance crew? So sorry, that happened!tore apart my 340 out of my cuda, paid a friend to assemble for me, head tech at a local car dealership up the roadView attachment 1717077View attachment 1717079View attachment 1717080 forgot the copper oil pump gasket, thanks buddy
Absolutely Nothing- I responded to the topic not your post.I understand how to clay bar a cars finish, I just didn't know what it had to do with the subject of cleaning seatbelts...?
head mechanic at a dodge dealership, actually worked on my hellcat, no more.That’s sad, you trust someone and they do that! Head tech for what, the maintenance crew? So sorry, that happened!
absolutelyDid the head mechanic have dirty knees?
