Rim and backspace sizes for 1968-70 charger
TexasRoadRunner68
1:06 AM
Dallas,Texas
What size wheels will fit on a charger? I’m mainly interested in centerlines and draglites, but might go with bassets or Aeros short term.
I’d like to go as wide as possible out back.
Thanks in advance. I just need to know what vintage rims to keep an eye out for.
i ran 10 with 4 1/2 back spacing.
What year charger =early ones are
harder to fit a wide tire and wheel?
I have several sets of Centerlines and Draglites in the shop
This car......
Has 18 x 9" front wheels with 4 3/4" backspacing. 275-40-18" tires.
18 x 10" rear wheels, 4 3/4" backspacing with 295-35-18" tires.
From 2003 to July of this year, I ran a 295-45-18" rear tire and I would get tire rub on the outer wheel tub at the rear.
68-70 B bodies have a weird bulge in the outer wheel house that intrudes into the wheel well.
I modified the bulges in this car as well as with my "Jigsaw" Charger.
Increasing rear tire clearance in a '70 Charger.
This car......
View attachment 1377759View attachment 1377760
I’m definitely aware of the bulge in the outer wheel house. I’m looking for rims for my 70 RT, and I’m trying to avoid doing too many permanent changes. Can you run a 15x10 on the rear without much rubbing?
My tires were 28" tall and with MP 440/Hemi leafs and a 1 inch lowering block, I'd get rubbing when I hit some bumps. No lowering block and I'd rarely touch.
Now with the wheel well mods and shorter tires, it all clears.
Stock:
After the cutting and welding:
15x10's will work on the back with the proper backspacing. Every car is different, so you will have to measure carefully. They will be somewhere between 5" and 5.5".
Looking at 4 1/4 back spacing rim with 26 x 12.00R15LT tires ,want to put on a 70 charger,Is the 4 1/4 to much for the front drums?
I think that would work but my cars do not run that wide front rims
or that wide of a front tire so it is out of my realm of experience. It has
been a very long time since I have run front drums either 10 or 11 inch.
fronts are smaller,just was asking about backs. Thank you:thumbsup:
They will clear the drums with that backspacing or even
5 back spacing on the rear given stock width 70. I would
be more concerned about rubbing on the 1/4 with that backspacing
and a wide tire with 4 1/4 BS on a 10 inch rim.
Chrysler O.E. Steel, Black, 15 in. x 10 in., 5 x 4.50 in. Bolt Circle, 5.50 in. Backspace
Part Number: WVI-63-5012052
So a 15x8.5 inch wheel with 3.5" of back spacing will not fit well on a stock 1968 Charger?
The problem with most aftermarket wheels is they are usually designed to fit the most plentiful cars. (GM)
Factory Mopar wheels typically place the wheel centerline closely in line with the mounting face.
Example:
15 X 7 factory steel wheel with 4-1/4" B.S.
Typical outside wheel width is 1" wider than the inside width so it is 8" outside. Half of that is 4" so a 4-1/4 backspace is +1/4" offset to the inside. Wheel mfrs call that positive offset.
So your 3-1/2" B.S on 8-1/2" wheel (9.5 O.A./2=4.75 CL). will put the wheel 1-1/4" outboard from wheel centerline. (Negative offset) More likely to get into the wheel lip.
Assuming stockish suspension and brakes, Mopars typically want zero or positive offset wheels. Aftermarket brakes or custom suspensions need to be looked at on a case-by-case basis.
18x8 (4.5in BS) and 18x10 (5.5in BS) with 245/40 and 295/40 Nitto 555G2's
You MIGHT get away with that on a 68 charger cause of the wide open wheelwell. You might not be able to run as wide a tire as you would like.
I have two pair of vintage wheels (ansen pro stock, and American daisies) with that exact size and backspace...... and they won't fit anything I own. (NOT enough backspace, 4 1/2 bs is FAR better!)
