icetech
no.. there is a thrust plate that goes on the front of the cam that keeps it from going forward and the timing gear won't allow it to go backward.. if you don't have those on just move the cam to where the front journal lines up with the front of the block and the lobes should line up thenNo those are Howard's rollers. Came with the cam.
So when I put it in. I lubed the hell out of it an pushed it in as far as I could. Your saying it's highly possible that it's too far back in the journal. Is there anything that is supposed to be put on the back of it to keep it in line perfectly. Or does the oiling gear keep it pressed against the thrust plate. Because looking at the pictures it seems like moving it back towards the front would solve my issue
