- 11:02 PM
- Apr 13, 2012
- Granite Bay CA
It is cheap and easy though, just like my cousin.
Yes still the same silver or whats left of it. The bulb is similar to what you pictured, here they are with a pic from Amazon:Are those housings still the factory silver paint inside?
I think that these types of bulbs....
Don't produce enough light, certainly not as much as an 1157. The aftermarket LED boards that fit into our housings must aim the bulbs straight toward the rear instead of in a 360 degree pattern like the bulbs shown here. If the bulbs aim at the back sides of the red lenses, it seems that they would be brighter, right?
Friends don't let friends buy cheap LED bulbs.Yes still the same silver or whats left of it. The bulb is similar to what you pictured, here they are with a pic from Amazon:
When they were linked I added them to my cart to look at later, and they are so cheap I figured what the hell and bought them while getting some other things. The light output while it was in left turn mod was really good for daylight. I'll try to get another pic later when I go to fish the OG bulb out of the housing with the brake pedal pressed.
If the housing is reflective enough I can see it not needing to only aim at the lenses, I could be thinking about it wrong tho. Either way I don't want to mess with resistors or change my flasher so this is likely just gonna go on the parts shelf and I'll buy some of that white paint.
I know, when the bulb was linked I'm pretty sure the person said it worked with their stock flasher. Either way I don't want to make that change, so white paint it is.You need electronic flasher.
Putco bulbs do work with a mechanical flasher.I know, when the bulb was linked I'm pretty sure the person said it worked with their stock flasher. Either way I don't want to make that change, so white paint it is.
He mentioned you slop it in.9 pages in this thread and I don't think I saw the procedure for painting the insides. Pour paint in, toss to coat, and pour the paint out? Asking for a friend. @Kern Dog
I feel like there is a "Thats what she said" type joke in thereAnyone I know?![]()
I wanna try it too.Either way I don't want to make that change, so white paint it is.
What's Pura? Is that like a grit?I must have bought the Puta bulbs!
Or "I knew a girl like that once"I feel like there is a "Thats what she said" type joke in there
