ZR9B
Just wondering if anyone has run the edelbrock 7194 cam. I look for reviews and don't see any love for the cam...I would think it should run like the .509??
I already have the cam and dont like what I have in there now I just dont see one good thing posted about it. thanks
1,500-6,500
Intake Duration at 050 inch Lift:238
Exhaust Duration at 050 inch Lift:246
Duration at 050 inch Lift:238 int./246 exh.
Advertised Intake Duration:300
Advertised Exhaust Duration:308
Advertised Duration:300 int./308 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Valve Lift with Factory Rocker Arm Ratio:0.480 int./0.495 exh.
Lobe Separation (degrees):110
Camshaft Gear Attachment:1-bolt
1,500-6,500
