Crumley
ckessel:
I went to the local Sherwin Williams Auto Paint store. All they had was the 3M epoxy and the special double barrel application gun....the epoxy was $30.00 and a heck of a lot more epoxy then I would ever need. The 3M epoxy application gun was $50.00, this is very pricey for what little epoxy that i needed. Because I needed such a small amount the gentleman working the counter suggested going to O'Rileys, they sell small 2 part epoxies. O'Rileys carried JW Weld brand, water proof marine 2 part epoxy. It comes in a small double barrel syringe applicator for $8.00 bucks. It should be more then enough to do what I need.This stuff set up rock hard in about 24 hours.
camtra:
Thank you for the complement.
Well I had some time to work on the 64 today. I finished drilling out the left side tack welds. Also took the trusty rose bud out and removed lead. There was a couple pesky tacks that was hard to see and one that was behind the rear panel that extends under the rear bumper. I had to drill this tack out from inside the trunk. The 1/4 panel is now laying in the floor.
The back window mechinisem is now sitting in the parts cleaner. I have begain the process wire brushing the inner steel structure, so it can be POR 15'ed and painted.
After the post from malex, I will be modifying the front of the left fender well to allow for bigger tires. I will go back to the right side fender well at a future time and modify.
Some additional pictures for the picture hounds out there see attached:
I forgot, this is about the 3rd mouse/ rats nest that I have cleaned out....lol:
camtra:
The back window mechinisem is now sitting in the parts cleaner. I have begain the process wire brushing the inner steel structure, so it can be POR 15'ed and painted.After the post from malex, I will be modifying the front of the left fender well to allow for bigger tires. I will go back to the right side fender well at a future time and modify.
