Nice build!!
Thanks for the kind words! It's takes a lot of commitment and hard work for sure.Nice build!!
Nobody?Ok guys, I have a question for y'all.
Last year, right before disassembling the car, my drivers door opened and closed perfectly without any issues. I have hung the door back on with the same hinges, and now it drops maybe 1-3 tenths of an inch when the door is opened, whic in return causes the striker to audibly jolt the door upwards when closing it.
When I took a closer look, I found the lower hinge is missing the spring assembly. I probably lost it. Should this be affecting the alignment at all?
I also cannot seem to get the upper hinge to slide forward... if that's the fix. Any ideas?
Thanks, and yeah I'm gonna play with alignment some. The two reasons I'm doing the work myself, is because it's much cheaper, and I want to learn. I don't know if I'm up to the challenge of paint, though.It sounds like you may have already fixed the problem but I do not think the spring will affect the alignment of the door. My roadrunner lost its springs many years before I got it and it closed perfectly. Hopefully I am giving good info but it sounds like it is just an alignment issue. Did you take the hinges off when you took the door off?
You car is looking awesome man! I wish I had the courage and the time to have done mine myself. Great work!
They're not for sale yet last time i talked to them. Probably ready in the spring.AMD makes a bulge hood? Steel?
Thanks for the kind words, Bb70. I'm hoping to get back into the garage tomorrow and do some more!Wow bud car is looking good . I can't believe how much you have gotten done since last time I looked . Wish I can start on mine . We're getting close I think 2-3 more months before I am realised by the doc. Keep up the good work.
Thanks for the kind words, Fitz. I'm hoping to have another update due soon.Awesome!
Thanks! It really means a lot coming from you; "the master restorer" I'm hoping to have the car in paint by july... Should be fun! This is my first major project and I really hope it turns out good.Man great progress on the body thus far....Keep up the good work!
Brings back memories for me to my first restoration....at home in the garage cutting and replacing panels....Thanks! It really means a lot coming from you; "the master restorer" I'm hoping to have the car in paint by july... Should be fun! This is my first major project and I really hope it turns out good.
Oh and one more think I'd like to say... AMD lists many of these parts for the 71-2 Charger "only" but I have found they all fit the 73-4 model perfect, with the exception of one quarter panel support that had to be cut and bent slightly. If any of y'all want the info on the 71/2 parts fitting on a 73, I'll share the info.
