Tim Chavez
hey guys.
youtube is failing me and i can not get this damn 340 to stay running...
Heres the specs
its a 1970 J head 340
long tube headers
Edelbrock 650 with manual choke(rebuilt myself)
vac advance HEI style all in one, two wire distributor
performance ignition coil
new plugs
new wires
new oem mechanical fuel pump.
it will not even try to fire without being choked.
choked it will start firing intermittently (almost like not all cylinders are firing)
but with throttle it smooths out to sound normal (but this is around 1600-2000 rpms)
once its acting like all cylinders are firing is when i let go of the throttle and it will drop down and die immediately (again sounding like cylinders are stopping firing then dieing completly) if i hold slight throttle it will stay running longer but will eventually(about 30 seconds to a minute) it acts like its running out of fuel and will die. if you play with the throttle and keep it at high rpm, you can keep it running (and driving) but it almost always dies without at least 1/4 throttle help (sometimes with 1/4 throttle it will die).
when it dies it always puffs air back out of the carb.
so i'm lost....
do i look at timing, fuel, ignition, the carb build, Carb tune?
driving the engine sounds and feels like all 8 are firing just fine(no major vibrations and smooth engine roar)
all your help is greatly appreciated
Heres the specs
long tube headers
new plugs
new wires
so i'm lost....
