Bought a stud kit for a sb engine, the rear stud is short of bottoming out in the block and the nut is nearly too tall for oil pump clearance, was going to contact ARP about a longer stud and a shorter nut and washer to clear the oil pump, figured I'd throw it out there to see what others have come up with, the engine had a stud kit in it when I got it and is obvious missing the stock bolt, and not sure if that would be a good idea to just get a bolt with studding the rest of it. Thanks in advance.
