440 engine I found
Updates. A steel forged crank for a 4 speed transmission and I have a 1967 a833 to match it. Trouble is I don’t have the bell housing. We need someone to make a wrench that has six holes that can be bolted to the flex plate bolts holes on the crank to beable to have more power to rotate a stuck engine.
55D4788B-C643-43C6-8C1F-AD9039948652.jpeg 2C69E818-D165-4D10-ACE4-DF769C5A8CD5.jpeg
So now I’ve wd40’d the entire inside. What I need is a u bolt with threaded hole ends with a sort exhaust stud that comes in the package screws into each side u bolt and screws into the rod ends so I can hit it with a rubber hammer not hurting the sleeve where the bearings go if plan a doesn’t work. That’s a good plan b because the crank is stuck I will have to begin rod and piston removal to loosen the binder forces. But first before anything camshaft and timing chain and timing gear assembly removal.
AFEC5CCC-1DF1-426C-944C-EBCFDF4D4FF3.jpeg BB5695C6-4148-42FF-95CF-ADEA4239EEE7.jpeg 0D5A8158-09F9-4E39-AE7D-37CE2B3E3A5C.jpeg
More updates. I forgot to add in the high impact socket when getting the balancer off:
6193C298-F99C-4E1B-AF27-7C681F141CF7.jpeg 86483FF4-CBA1-4B88-8336-B536346EBF31.jpeg 04F58004-890C-48ED-8C45-C265CFDEF0B1.jpeg 78CD8C94-D75E-486A-9A95-4D5B55FAE6F5.jpeg 6B5CAD03-8D1D-47A0-946D-135359091947.jpeg 0C462122-5387-4A18-A1B3-CACB7BC2BC32.jpeg 039ACE4C-76BA-44E7-AD16-377C9E914411.jpeg 8BFC21E8-0DEA-4836-B24C-D7BA7FA7061D.jpeg 2474AB84-9DB4-4C73-A82C-52525BC9C179.jpeg
My dads antique snap on at work still to this day lol but still won’t turn over so I depressurized the mains and put more wd40 going to wait until tomorrow to see if it turns over if not well I’ll go from there.
053C0CC9-0A6F-4FD1-9B90-03F8EAFB7E22.jpeg 12185715-745F-4976-BF9D-F9F09A53BA8D.jpeg A8F174FE-FF33-48D7-8823-4E5C5BB5774A.jpeg 21316830-86D9-4A8B-8842-9397B4A78E6D.jpeg 3CADBBC6-3AC5-4198-8563-B84C79D4A9CD.jpeg
This engine has turquoise…. Chrysler is blue dodge orange and Plymouth turquoise… this might be a Plymouth motor.
Goodnight y’all I’m taking a break and about to go to snooze patrol.
Wrong...All three used turquoise orange & blue.... The colors are year dependent & 67 was turquoise whether it was Chrysler/Dodge/Plymouth or Imperial..... And LP or HP... All were turquoise...
thanks for the lesson.
Updates blasted the heads because I believe when they re sent off to the machine shop for new valves and springs it will be hot tank. I can’t blast the motor thou because of the water jacket and sensitive metal areas. Got the heads date codes.
22B7471E-A883-421D-979C-B2684A0BE9E8.jpeg 1A882AED-47EC-45B5-838F-EDB6599B56BE.jpeg 35CF160F-F8B3-483C-9DE9-2D458A444140.jpeg F80FF06F-154B-44C1-A352-C33CB5C206FA.jpeg 30D693E1-EB08-462C-8D20-B72072EF7FF2.jpeg 99176166-E465-4140-B33D-0033D8F2EE4F.jpeg B356E42E-BBED-4754-8CFC-AD9AA95AC121.jpeg 8D6464CE-FC46-49B8-8590-6FA822FAEA49.jpeg 3EDE47E6-1B55-4467-A9C7-2EA674C65A24.jpeg 61364487-DA5F-4C62-B132-632758F5AA36.jpeg
Shop is a mess. But here’s more pictures. It’s a A stamp meaning .20 over bore from factory what I read.
57837086-4205-456A-973B-D673B1077208.jpeg 4BAD488F-CA77-48BC-9E93-B83862B7322F.jpeg 6FAAD4CE-DE0C-4F8E-9183-065B6CB15DFD.jpeg 6117E696-66A4-485A-8AEB-AC537BD0C925.jpeg 6A988C55-CDD3-4EF5-BD4E-E4885ECEC9D1.jpeg
Rods are intacted. So the mystery I’ve gather is the thrust main bearing spun put the motor out of time leading to bent push rods so that’s what I think made this thing be pulled from the car. The crank has to go be rounded.
7BAB0132-F468-41A1-9373-7800791E74F6.jpeg 8695E573-90AB-438E-9074-591296EAF3E6.jpeg 69F401D1-05A7-4C5F-93C6-A5F4D680835C.jpeg 2DEAA369-C4F0-4BB1-8827-42DA5BE3879D.jpeg E4FDEAFB-DB95-4D3B-9D08-BDF53B956901.jpeg 4BA0175D-F2B7-4F6E-AF4D-852BD8D83E7C.jpeg FBAD81FD-E43B-4E2F-A204-94C2633D9207.jpeg 5DB7FC19-6C2D-49EC-810A-584BEFCD6B23.jpeg 3FEFFB08-3059-4739-9FE5-21598530A7BB.jpeg
I have to get new honing blades and mark each cylinder with a micrometer I can’t figure it out with precision without honing the cylinders.
Tomorrow I’m going to clean it up very nicely with the four barrel and paint it turquoise and put it in the house for now.
Mopar gods are pushing back the negativity in the house I believe haha with all these car parts haha.
I have clean up to see if they re matching date code 915s. So far better than expected my luck you know. will need to be bored I’m pretty sure. Non hp stamp 915 heads found that out. The block is not stamped hp. I have to get the vin code of the back also for y’all.
View attachment 1147938 View attachment 1147939 View attachment 1147940 View attachment 1147941 View attachment 1147942 View attachment 1147943 View attachment 1147944
Yeah those look like the smaller exhaust valve heads but still closed chamber.
Just have the machinist put in the bigger valves and hardened seats when you have them rebuilt.
As far as matching date code, if they are within a couple 3 months of each other they probably are a matching set.
