Sounds like the machine shop might be able to get moving on my block sooner than I thought.  At least he said I should get some parts ordered.  I am not sure if he was saying that, because he is getting to it soon or if he thinks it is going to take me a while to get the parts.
Anyway, first up is cam bearings.  I want to go for the Clevite SH2152S.  It looks like the soonest ship date I see is from Jegs on 2/21/2022.  Is this the best bearing for my build?  Is it worth waiting if I have to wait for a month?  If the machine shop wants/needs them sooner, does anyone have a secret site that has them in stock?  If not available soon enough, what is the next best option, manufacturer and part number?
Bolts, get a complete set or just specific areas.  I was planning on head bolts and rod bolts.  Also saw where someone said you can reuse your main bolts, but if you are upping HP, you may want to to replace them as well.  Thoughts?  I am planning on ARP for all those bolts:
Connecting rod bolts - ARP-145-6002
Head bolts - ARP-145-3606
Main bolts - ARP-140-5002
Are there other bolts that really need to be replaced?
Rear main seal, I want to get the Mancini Racing Billet Rear Main Seal kit, Item #: MRE223.
Cam, Comp Cams Xtreme Energy 21-222-4 camshaft, grind number CRB XE262H-10.
Main and rod bearings, Clevite, but need to know what size to order once I talk to the machinist.
Pistons?  Unscientific down in the hole measurement was .056 to .065.  I really like the Speed Pro pistons, but lots to consider.  I was thinking of having the heads milled to .050.  I really do not want to zero deck it, you can’t put back on after you have removed it.  Edelbrock (planning on Performer RPM heads, but not sure on cc yet), guy suggested the six pack pistons to get them further up in the hole.  May still not get to the sweet spot on the quench.  Also must consider the weight difference compared to stock.  Do I have to get the crank balanced?  Does it add too much to the rotating mass and make it harder on the engine and rob horsepower?  Would like to be in 10.1 to 10.5 range and be able to run on pump gas.  Do I need to have the rods done and pistons for them to balance the crank?  Do I need the pistons for the machinist to mount up, so he can truly tell how much to mill from the deck?  Flat top pistons or flat tops with valve reliefs?  Is .050 the ideal for quench?  If so, with a .039 head gasket, pistons can only be .011 down in the hole.  So many factors to have to keep straight.
As always, your feedback is greatly appreciated.
Thank you!
Allan
