Correct application Hayden clutch fan?
Dennis H
4:27 AM
San Jose
69 Coronet R/T 440 non ac car now aftermarket ac. Is it the regular or heavy duty. Does heavy duty mean high performance or ac equipped? I am looking for the correct oem replacement thermal clutch. Can't see a part number with it installed. Thanks. image.jpgimage.jpg
HD could mean police car parts also,
I'm not 100% sure on the HD being the HP cars, some aren't HD equipped
allot of HP cars didn't have A/C, but could have had other HD parts,
like springs, trans cooler, Dana-60, 11"x3" brakes, bigger radiator etc...
it could be HD tow package &/or A/C stuff too...
HD as far as radiators, I would think, probably have a 26" radiator too {instead of the 22"}
sorry that's not much help
I saw 29 people had viewed/looked & that no-one even answered, at all !!
I know the HD clutch I ordered for my rig (Non-A/C) was deeper than the original TRW clutch and wouldn't fit. I ended up using a Hayden thermal replacement that was spec'd out for an AMC car.
Talked with 4 Seasons the Hayden Rep in Texas and he says it is the HD 2747 part number. He said to pull on it to see if there is movement indicating a bad bearing and look for oil indicating a leak.
Dennis, I know it's been 4 months since your last post on this, but what fan clutch did you end up getting and did it fit? Or was your current clutch OK? I've researched a lot on this for my car the past few months. The 2747 is indeed the HD clutch and I would run it on mine if it would fit, but it won't on my car. I came up with 4 other options:
- (For Reference, your Hayden HD 2747 is 3.375" from clutch to rad.)
- Bouchillon offers one (not sure if it's Hayden or not) that supposedly puts the clutch only 1/8" away from the rad. They claim no issues, but that's a bit close for my liking.
- OEM style re-pop FC-28: Originals no longer made, but Tony's Parts offers these at $200 ea, although it's for non-A/C cars. Not sure on clearance, but I think I read somewhere that it's 2.75" from clutch to rad. It's supposed to work and give plenty of clearance.
- Hayden P/N 2705 - 3.11" from clutch to rad. I just bought this and need to test it after I get motor and new Griffin 2 row aluminum rad installed. Meeps mocked it up on his '69 and says it's a little close for comfort. It fits, but I think it's within 1/4" of rad with his stock 22" 3 row copper rad.
- Hayden P/N 2765 - 2.67" from clutch to rad. This is the Jag clutch and many members here have run them successfully. This clutch gives the most clearance, BUT it's designed for the Jag, which had a light electric fan, so some members claim they only last a year or two before they give out. I may have to resort to using this one or no clutch at all for my car.
