I'm delaying right now just using the window switch in the 7531. I think it'll hold it all off the line so I'm going to try activating the spray at the release of the trans brake and see what it'll do.Do you spray off line or delay it?
The 440 would take a shot off the line. Not so sure my tires will hold with the 511 though.
Mine pulls at the upper inside corner at the front wall of the valve cover. No baffels. It'll go 25 passes pulling about 2oz of oil.On another note anyone have experience with vaccum pumps? Mine works great. Only issue I seem to be having is the little oil it's pulling seems to want to go straight out the breather on top of canister. Is there a recommended way to mount the canister? A certian length of hose? Right now it has about an 18" hose with a 90 fitting on each end. Does it need a straight shot, a longer hose? A shorter hose? Ideas. Thanks.
Looks like an adjustable vacuum regulator.What is that extra thing after the valve cover? A regulator or something?
I got one with my GZ pump but never used it. I never even put a gauge on it. Do you have a gauge on yours?Wonder if I should install one?
Your inbox is full. I wanted to PM you about something but can't.I got one with my GZ pump but never used it. I never even put a gauge on it. Do you have a gauge on yours?
All cleaned out.Your inbox is full. I wanted to PM you about something but can't.
