Mr. Belvedere
Just rebuild it but upgrading to 11/16’s tie rods and adjusters. I also got PST 1.03 tb’s so it should stiffen the handling up, along with the Stage 2 power steering box from Steer n Gear.
Today I got the Bouchilon throttle/kick down installed and started running trans cooler lines (waiting on some sleeving from DEI).
95492D72-4319-44E2-A3E6-5BF44B9BA3A6.jpeg 3FED5C8E-C379-4DD3-A4FA-723D3DDF7A25.jpeg A2E9A70C-19A1-481A-852D-F7A9FE31720C.jpeg 0D6A1667-7CAB-4FD7-BA4D-E8212A4DFB95.jpeg 830B9469-0FA5-4956-B569-122B9ED166DF.jpeg
That looks really tight around the power steering gear. I don't remember if you said, is it the stock gear?
Yes, stock power steering that is a Stage 2 rebuild from Steer n Gear. There’s plenty of room, I can get my hand in between them.
I see you mounted the throttle bell crank to the engine. Did you fabricate that bracket? Or is it a part of Bouchillon kit. I like that better than the way mine turned out.
That is from Bouchilon, nice and compact but rather pricey.
I was not aware that you had to open up the trans tunnel for a GV. Is that a G3 Hemi thing?
I didn’t know either. All I’ve ever read was “a ding here or there”. But once I started jacking the trans into position, it was apparent that surgery was in order. I kept it as small as possible, but that damn speedo sticks out quite a bit. I raised the tunnel about 1/4 inch and gave a good amount of room for the speedo connection.
I wish I had a slip roller and a brake and this tunnel would have been so much better. But I don’t, so I had to make it out of 6 pieces and weld it all together.
12F77EF5-EDD1-484D-A7A0-C3B482183EF6.jpeg E1E07874-9D82-4829-95FE-C6078F78C844.jpeg
Finished all the wiring, got rid of the factory starter relay, gutted the ballast resistor (has a regular wire in it now for 12 volts run/start) and at the ignition switch I combined the brown/yellow with the pink wire from the Hotwire harness and then the yellow on the switch with the yellow on the Hotwire harness. Double checked all my connections (power probe) and all was good. So then I connected the battery for a “smoke check”, no smoke and twisted the key. It lives!!! I have a small video of it running, only a few seconds as I still need to add water and tranny fluid.
That is exactly how I had my 68 Charger wired when I first fired it up. It always started right up but once in a while the engine would flutter and not seem to run properly. While speaking to Chris at Hotwire, he told me the computer doesn't like the millisecond break in continuity when the ignition switch goes between start and run and sometimes will act up that way. I finally ended up using a push button start and have not had that issue again. Some people have not experienced the problem but if you do happen to notice that flutter, that is what the problem will be. I didn't want to add the push button but now after a couple years I have gotten used to it not being part of the ignition switch. My button is under the dash where a common thief would not easily figure out why it won't start.
I rebuilt a 489 case, clutch sure grip, new bearings, 1350 yoke, used gears (3:23’s) from my dads 70’ Challenger RT with crush sleeve eliminator and seal. Damn thing took me 7 hours total to get a good pattern.
86489E64-1C14-4399-BA3E-47611311144C.jpeg 7456EAD2-6949-430E-AB56-26C1068918BB.jpeg AE5DB11F-1D20-43EE-905A-E96B9BFCF13B.jpeg D0A41FEF-81CC-41C7-9FFE-D0D7D2D8E40F.jpeg
Got some work done, and still have more to go.
098214AB-6363-4701-903C-0B763DB08295.jpeg 94E0EF11-B3A4-4C08-ABF5-8DE99FF2C2F6.jpeg 7EB8AE91-4F64-49E1-BC56-1BA1D15A4007.jpeg B63A8381-095E-4D12-83CD-943B17CD3C42.jpeg E9C01A21-C715-4E2D-AFF9-0FA93A252E3C.jpeg FF5FD8AF-B858-4062-8E8A-31C3967561D1.jpeg
The front end was shot, so I’ve got all new parts going in. Waiting on a strut rods (adjustable) to finish. Power disc brake conversion going in also, drilled/slotted rotors.
09EBCA4E-8C55-44D5-A9BB-BBBD0A0FE3CB.jpeg 5DF738A2-D781-4802-ABA7-15BD1F001809.jpeg AE8189C7-8BB1-4F42-9A26-357D3A8CD852.jpeg E2E5284C-3630-4847-9AA2-08F945E369C4.jpeg 28D22F05-E7EA-4E12-97B1-137E2D15AC2F.jpeg 74A7B809-E370-4042-8CA3-CD8B945DFE5C.jpeg
Was a busy day. Parts were jumping onto the car! One nut that holds the booster backing plate is fight me, not nearly enough room to get a socket up there, but it WILL come off! I ordered a high pressure hose kit for the power steering, was super easy to install the fittings. Lol! Here’s today’s festivities, enjoy.
95E05A66-80BA-4AA1-8694-8610464EBE5A.jpeg 3213F791-6B1F-41B2-8B67-5A9CB67B9B0B.jpeg 4BD40154-4B05-4017-B290-6379F3154BC0.jpeg 16F8A4CC-F1DD-47F1-8556-35695EEBDDA8.jpeg 6449502D-E5D9-44B1-9336-F78312F48159.jpeg 789339D7-7376-47FE-8937-E472A9FD0160.jpeg
Getting more parts thrown on this.
D4134CB1-8E23-4527-889C-BA12BEAF19DC.jpeg 1F4B2722-090F-4FCF-BD0D-79598F987D1B.jpeg 88197C6D-BB8A-4C95-8E3F-9F64DF9BC8D6.jpeg 777799F7-204C-43C9-9378-54092D85D471.jpeg
