nodust
- 7:32 PM
- Apr 14, 2013
- red deer alberta canada
Thanks, good for you!
The Computer uses one of those oil pressure senders for its info to turn on the check engine light. If you install a oil pressure gauge, you will need to install a sender for it.That sending unit will need to come off and a pipe plug put in its place
I don't recall for sure but I think the computer uses all of the existing sensors. It's been about 4 years since I dealt with mine but I do remember needing to use one of the oil sender plugs to add a sender for my gauge. Plus drill and tap the hole for the water temp sender for my gauge. Yours may be different. Plus maybe the 5.7 is configured a little different than the 6.1 too. Anyway, I'm sure you will get it handled.True, but there is already 1 on the block along with some other sender in the front....that one could be reading oil temp.
Stock tubs?The rim/tires for the rear fit, but it’s tight on the drivers side so some trimming is necessary. Also getting XHD leaf springs and new shocks all around along with a front sway bar.
View attachment 730222 View attachment 730223 View attachment 730224 View attachment 730225
