My brake lights aren’t bright enough
With the switch closed, the pink wires have power but the white wire does not. With the switch on, both wires have power.
OK, that makes no sense at all.
Switch Closed means switch plunger is depressed....which means contacts are closed, and power (voltage) should be present at both terminals.
Switch Open means the switch is at rest, and consequently voltage present at only the incoming supply side - in this case, the Pink wires. White goes off to the rest of the circuit.
I posted this a few weeks ago over in the electrical forum.. Although specific to a 66 Charger, think you may find it helpful to solve your problem. There is a Drop Box link to down load all the info and diagrams.. 66 Charger, Turn signal repair
I had it backwards then.
With the plunger of the switch extended as if the brake pedal were pressed, both terminals get power.
Hey… I’ve heard plumbers and electricians use wrong terms when talking about carpentry too….
I’ll check that out when I’m in the house for the night. Thank you.
Here is further example of my limited electrical knowledge…..
Yes, the turn signal switch CAN affect the brake lights without the turn signals being on. I did not know this until now.
I know that the switch interrupts the brake lights to transmit a momentary pause in the brake light to “flash” but I didn’t think that the switch could just block the brake lights entirely.
I disconnected the switch and still saw no brake lights. This told me that the brake light signal enters the switch and then comes out somewhere else to the harness. So far, I can’t find the path in the FSM.
I plugged in a spare turn signal switch.
Boom. Brake lights!
Now I have to replace the switch in a steering column that I won’t be keeping in this car. It is a column shift unit and I’m going to convert it to floor shift someday.
The 1970 column is a one year only design that has value to those that need it so I’d rather not modify this one. I guess I’ll just replace the turn signal switch for now.
You got it figured out. Nice job. I was going to say yes the TS switch can stop the brake lights from working as you said it controls the brake/turn lights together.
Thank you.
It does feel good to figure something out when it isn’t your strong suit.
This is how the system looks now.
Brake lights, no tail lights. Engine off.
Yeah, the lights are brighter with the engine running.
Now the brake lights and tail lights with the engine running.
This is daytime.
Now I replaced the two incandescent RH brake/turn bulbs to these:
Yeah. I was surprised too.
Streetrodders many times, paint the insides of their taillight buckets with gloss white paint, several coats. It's a lot brighter than the rough silver is. Rustoleum has an appliance epoxy that is very durable and very shiny. It does come in brush on cans, but you have to order it.
Is this what you mean?
I did spray that on one housing. I decided to try the flat/satin paint based on the advice of Daniel Stern.
I was gonna say wiggle the turn signal and see if that helps but you figured it out, I think I had an issue like that when I first got the Net a year ago.
This has been like a game of Whack A Mole.
I started off with no brake lights. While I worked on that, the taillights quit working. I figured out the brake lights were dead due to a failing turn signal switch...I plugged in another, it worked fine for a few minutes then the brake lights went dead again.
I tried another turn signal switch, again....just plugged into the harness, NOT fully installed, and I have brake lights again.
I can wiggle the wires leading to the fuse panel and the taillights will come on, then sometimes shut off. It is a loose connection issue.
It is like the Lord himself is throwing problems at me and laughing...I fix one and another gets thrown at me.
I had all the lights working fine but a few weeks back I was under the dash on a brake conversion and I moved a few wires. The wire to the BRAKE light touched the parking brake lever and smoked! I'm guessing that may have damaged the turn signal switch.
Whack A Mole continues.
Brake lights, turn signals and taillights all work great. Somehow, the right front turn signal in the valance quit working. I tried another bulb and another housing and got the same thing. Can a turn signal switch somehow cause that?
I had the key ON for about an hour and it sucked the battery down to 11.74 volts.
30% ? How peak must a battery be to go dead that fast ??
I'm thinking gloss white would work better than flat white, but I've haven't done it myself yet. Rustoleum has what they call appliance epoxy. It only comes in white, black,stainless steel and almond. Walmart usually only has the white and black. I use the black for all my engine brackets, bolts and anything I want painted gloss black. The white come in brush on cans, but it's special order.
When I worked in a paint store in the 90's, Behr had a display showing their Ultra Pure White vs several other brands whitest white (latex house paint). There was a significant difference. Behr says it's due to the amount of titanium dioxide they use ($$$$).
I can't remember how the oil based and spray paints compared. Ceiling white isn't a pure white, it's color and sheen is formulated for proper light characteristics.
How about a comparison?
The car on the left is "Ginger", while it isn't perfect, it is the nicest car I have here. On the right is Jigsaw, the one that I've used for this taillight paint experiment. This is just the taillights:
I am not as well versed as Daniel Stern in determining levels of brightness but it does look like the car on the right is brighter.
Trying to get the brake light brightness was difficult. I used the flashers and between the two cars, Ginger's flashed faster than Jigsaw's lights.
If I had two people here to just get in and press the brakes, I could get a real test.
I think as I was trying to "time" the picture to get both cars with the flashers ON, the car on the left was either just coming on or going off.
Still, check out how bright those brake lights are!
I watched the video and the Putco's are by far the brightest. With the brake lights on, the perimeter is red but the center is bright white, more like a headlight. I'd want a brighter red brake and taillight, rather than just brighter. Just one man's opinion.
They're definitely red in person. I have them on my car.
