No oil through passenger rocker arms
Engine, Trans & Driveline
  1. 69Bee
    69Bee FBBO Gold Member FBBO Gold Member
    1,848
    1377
    Nov 17, 2009
    Whetstone, AZ
    Local Time:
    8:17 PM
    The shaft oil hole will be towards the valve in relation the shaft hold down bolts. If there are notches on the end of the shaft, the driver side shaft will be to the front of the engine, and to the rear of the passenger side.
    • Like Like x 1
    • oldbee
      oldbee FBBO Gold Member FBBO Gold Member
      8,265
      8103
      Oct 15, 2011
      NE Ohio
      Local Time:
      11:17 PM
      Like miller says, straighten a coat hanger; lay it between the pushrods and pedestals. That'll keep the pushrods halfway lined up when you put rockers/shaft back on.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • 1968rt
        1968rt Well-Known Member
        162
        141
        Jul 28, 2010
        New York
        Local Time:
        11:17 PM
        If its bone dry it could be the cam bearing. Either installed wrong or it spun!
        • Agree Agree x 1
        • wyrmrider
          wyrmrider Well-Known Member
          2,324
          902
          Aug 26, 2014
          los angeles
          Local Time:
          8:17 PM
          a BTW
          rotating the engine while priming will also load up the lifters if they were dry or bleed them down if they were loaded with oil (which can bend things)
        • 69Bee
          1,848
          1377
          Nov 17, 2009
          Whetstone, AZ
          Local Time:
          8:17 PM
          Trick I learned and it might have been in the service manual, use the oil dipstick.
          • Like Like x 2
          • Agree Agree x 1
          • dadsbee
            dadsbee FBBO Gold Member FBBO Gold Member
            5,486
            11694
            Jan 29, 2018
            Ontario, Canada
            Local Time:
            11:17 PM
            Length of .063 TIG filler wire works perfect.
            • Like Like x 3
            • Thanks! Thanks! x 2
            • Yeahrightgreer
              Yeahrightgreer Well-Known Member
              73
              55
              Jan 12, 2020
              Camp Lejeune, NC
              Local Time:
              11:17 PM
              Plugs are indeed on each end of the shaft
              Yes, and only driver side head would Oil once per revolution
            • Yeahrightgreer
              73
              55
              Jan 12, 2020
              Camp Lejeune, NC
              Local Time:
              11:17 PM
              I got a chance to quickly look the car after work but the sun is down and I got rained out so limited
              I started by just double checking I didn’t miss the hole while priming, so I slowly turned the crankshaft while priming. 3 full revolutions for the camshaft, driver side oiled every time and nothing on the passenger. I then removed the shaft assembly and did it again and still nothing out the passenger side.
              I didn’t have a pipe brush small enough to fit down the oil gallery so will have to try tomorrow or use a small wire to see if there’s debris etc in the way. I’m hoping it’s that and not a cam bearing.
              • Like Like x 2
              • Agree Agree x 1
              • 69L48Z27
                69L48Z27 Well-Known Member
                2,682
                2784
                Nov 19, 2015
                York, Pa
                Local Time:
                11:17 PM
                When you poke the wire down through have someone turn the engine over. If the filler rod never finds the hole in the cam you’ll know what the problem is. If you find the hole on the cam then it’s a head scratcher.
                • Agree Agree x 3
                • 69Bee
                  1,848
                  1377
                  Nov 17, 2009
                  Whetstone, AZ
                  Local Time:
                  8:17 PM
                  1) Head gasket is symmetrical, so can not be an issue
                  2) Crap in the passage is possible.
                  3) Spun or misaligned cam bearing is also a possibility.
                  One thing to think about is the heads are drilled on both ends so that the heads can go on either bank, as well as the gasket. A head that was together for many years can build up a gross grey sludge from years of the OLD oil. The sludge forms because the head gasket blocks the hole at the head level, and oil yurns to sludge over time in this blind hole. When I clean these heads, and blow out the rocker bolt holes, the grey sludge comes out thick as tar. Push a rid in the passage, and if it is covered in a grey sludge, that might be your issue. Carb cleaner and an air gun can clean it up. The carb cleaner straw does a good job of conforming to a shaft the is not straight. Wear eye protection, trust me and don't ask how I know.
                  • Agree Agree x 2
                  • Like Like x 1
                  • miller
                    miller Well-Known Member
                    4,083
                    2005
                    Jan 5, 2014
                    Tom Bean,Texas
                    Local Time:
                    10:17 PM
                    Sounds like you've found your problem. A good thing, since running it like that would have gotten bad.
                    Okay, find out why?
                    When the cam bearings are installed, there's two holes in #4 bearing. IF the bearing is right, the bearing holes will be lined up with the two block ports. Yeah, run a stiff length of wire through that hole, to see if any junk comes back out with it. A little harder, push the wire in 'til it bottoms...turn the engine by hand, to see if you can feel the wire end, moving along the cam journal.
                    Bottom line...if the cam bearing is NOT right, cam needs to be pulled, and cam bearings re-done.
                    Toss a handful of common sense at it all, and go from there. Good find, before things went south!
                    • Agree Agree x 2
                    • Yeahrightgreer
                      73
                      55
                      Jan 12, 2020
                      Camp Lejeune, NC
                      Local Time:
                      11:17 PM
                      There is supposed to be a shaft that the oil passes through correct? So in other words this specific hole on the second to last bolt hole should be deeper than the other 4?
                      Feeding a wire through feels as if its not even protruding down and that it’s hitting something solid. Intuitively it doesn’t feel deep enough to be the cam or bearings. Maybe halfway down the cylinder head. I measured and it has the same depth as the other holes. Am I missing something?
                      • Like Like x 1
                      • khryslerkid
                        khryslerkid FBBO Gold Member FBBO Gold Member
                        20,387
                        29780
                        Mar 10, 2010
                        Hanover, Pennslyvania
                        Local Time:
                        11:17 PM
                        Can you look in that bolt hole with a good flashlight? A stiff straight wire should go down to the cam bearing.
                        • Agree Agree x 1
                        • Fran Blacker
                          Fran Blacker FBBO Gold Member FBBO Gold Member
                          7,565
                          7142
                          Sep 23, 2016
                          Connecticut
                          Local Time:
                          11:17 PM
                          Haven't done wedges but does the oil hole enter the at an slight angle not straight down, just asking.
                          • Agree Agree x 3
                          • Like Like x 1
                          • MarPar
                            MarPar If it weighs, it pays FBBO Gold Member
                            12,839
                            21436
                            Nov 21, 2008
                            In GTXtacy Illinois
                            Local Time:
                            10:17 PM
                            Greer buddy! Welcome to the madness that is FBBO!
                            I hope you get yer oiling situation all figured out.
                            • Like Like x 2
                            • Agree Agree x 2
                            • 69Bee
                              1,848
                              1377
                              Nov 17, 2009
                              Whetstone, AZ
                              Local Time:
                              8:17 PM
                              Rocker bolt goes straight down, and the oil passage angles towards the intake side of the hole.
                              • Like Like x 5
                              • Agree Agree x 3
                              • wyrmrider
                                2,324
                                902
                                Aug 26, 2014
                                los angeles
                                Local Time:
                                8:17 PM
                                old fuzzy here but the oil passage is off the bolt hole not straight down
                                borescope?
                                you pulled the bolt from the back of the engine or the front
                                that pic on the previous page looks wrong- maybe BBM
                                //sbm pump is at the rear
                              • Fran Blacker
                                7,565
                                7142
                                Sep 23, 2016
                                Connecticut
                                Local Time:
                                11:17 PM
                                Think intake ports facing down in picture. So hole is hard to with heads on in engine compartment.
                              • HALIFAXHOPS
                                HALIFAXHOPS hops farmer and MOPAR only distributor rebuilder! FBBO Gold Member
                                2,512
                                1002
                                May 5, 2016
                                Halifax, PA USA
                                Local Time:
                                11:17 PM
                                @MoparMitch had a good one the oil passage in the on one side of the cam was blocked same issue. Look at how the oil goes through the cam, it will make sense just something to check.
                                • khryslerkid
                                  20,387
                                  29780
                                  Mar 10, 2010
                                  Local Time:
                                  11:17 PM
                                  I thought I had read that on another website.
                                  If the cam bearing had spun, you wouldn't think that one side was still getting oil. It should block off both sides unless you were lucky enough for one of the two holes to stop just right.
                                  Upon my initial oil priming with a drill (fresh rebuild) I couldn't get oil on the passenger side. So I pulled that rocker shaft bolt and tried again, same result. So I used a stiff wire and sent it down the passage. (I don't remember going at an angle, thought it went straight, but I'm old too!) When I pulled it out I had break in lube on it. Turned the priming drill again and had oil. So I'm guessing it doesn't take much to block the small cam bearing hole.
                                  • Agree Agree x 1
                                  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                                    By continuing to use this site, you are consenting to our use of cookies.
