Oil for 512
19 69 GTX
12:44 PM
Just curious what oil everyone is using for 512 stroker street motor oil . All roller and are you using conventional or synthetic
I would just use whatever I find in my garage. If it's not a flat tappet cam engine that needs zinc, you can use anything that is the right weight for your internal clearances, and weather.
I tend to buy oil when it's on sale. Didn't realize how much I had till I put it all in one place.......
Check w engine builder on what they recommend w the bearing tolerances. Tight tolerance can use a 5-30, loose tolerance a 20-50.
I doubt you built a 512 stroker just to go to church on Sunday......
I would use syn oil for max protection; the rod brg speed is higher with strokers, which generates more heat & syn oil has a higher working temp.
