pedal2themetal
HI,
1975 Fury 318.
I'm at a loss.. Here's what it does and what I've had done.......
What it does,
Works fine for a while then it well turn over great and fast. but NO start, unless I barely turn the key.. an sometimes that don't work its worse now .. even barely turning the key doesn't always work.. and I mean Barely have to find the sweet spot.. and its a verrrrry small spot..
Whats been replaced
I've had the switch replaced 4 times 2 by me and 2 by shops the last one was a NAPA over $100.oo part installed by a shop as well as the key switch... In January this year 2022. It works fine for about a month then starts getting worse and worse. to where we are at now barely works.
Coil replaced , ballast resistor like 3 times last time by shop
I've cleaned the connection at the resistor wire thinking that might be it.. but NOPE..
I'm about ready to just put in a button that adds 12V to the coil to use when starting..
any help well be appreciated
thanks , take care, be safe
tim
1975 Fury 318.
What it does,
Whats been replaced
tim
