- 2:28 AM
- Jul 9, 2019
- Modesto California
well, the next step...
The pump is a standard rebuild for a mid 70s 440.Yes, GM metric. The pump you bought should also have metric threads at the high-pressure connection.
The GM OE hoses have metric fittings on both ends.
Bolt-in, OE engineered, no adapters, and you can save the part numbers for future replacement.
Yes, Mark.....The HB has these fittings.16MM 1.5 AND 18MM 1.5 FOR GM HYDRO BOOST PUMP
I believe this is what you have.
Edit; at the h-boost.
It was the billet style with the two O rings on each side.I probably missed it, but what rear main seal and retainer did you use?
