Stock 1970 440 rods, resized and floated with ARP bolts.
Cam specs say 5,800 rpm but it's still pulling hard right on past that. I'm only wanting to know what the rotating assembly will handle so I can set the rev limiter at a safe rpm.
Why in the world would you be revíng past 5,800 rpm,(the Cams rated max rpm), because of "seat of the pants" feel ?
I can guarantee 2 things.
1.) That if the Cam manufacturer says 5,800 rpm... even THAT would be generous, and more likely you are already on the downside past peak power by 5,500 rpm.... so going slower no matter what your "feeling" is !
2.) You are adding internal stress in the Engine by going past peak power.
You see.... it is NOT a "set" rpm that is the limit for a given set of parts.... it is as long as the set of parts can PULL against a load and still make power which is what determines longevity.
If the Engine can still PULL against a load, and make power... a product of Camshaft and "breathing"even shiatty parts will hang in there.
But conversely,
allow the engine to start "freewheeling" past where it makes power...
THAT... will shiatcan even the best parts ! which is exactly what you are doing with a Cam rated for 5,800 rpm.
just sayín....
just because it zips right past 6,000.... that doesn't mean it ain't WELL PAST peak power and is starting to freewheel !
Shift at 5,500 rpm and I guarantee you will go faster !
