No thanks.
Prolly has a blue tooth. That way it can report in how many times it is sat on and how any times it is flushed so it can report how much water is used.
I live in WI, I could dig a well with a shovel in about 3 hours. The state is surrounded by water. I have a well, I pump the water from the ground, when I flush it goes out back to the septic and returns to the ground, I do not "waste" the water like so many claim happens.
I will keep the Kohler in my house. It is blue, from 1975 and probably has something like a 8 or 10 gallon tank on it. It has never plugged once in over 20 years that I have been here. I replaced the mechanism, once, with a solid brass unit I got from  CESCO brass. If it ever starts to have an issue I can take a screw out of it and replace an o-ring.
The flush handle is chromed metal.
I am on the third seat, because apparently they can't make those right anymore either. 3 years after we moved here I threw the original out because the little step-pads on the underside that sit on the rim were broken up and missing pieces. Mistake, should have found a way to replace them. It is kind of cool(this latest seat) as it has these twist locks on the hinges so I can remove it without unscrewing it. Kinda nice for cleaning, makes it super easy to get around the hinges. But it will wear out like the others I am sure.
Seems plenty smart to me, it does exactly what it was designed to do without worry or malfunction. Could say that about a lot of things from days gone by, function and quality meant more than accountants and "muh carbon" and greed and control.
I wonder who Kohler will sell "the data" to? If it has a blue tooth I mean.
