Good morning all. So I added a vaccum pump to be able to achieve proper vaccum for my power disc brakes booster (big cam)question is it needs 12.5 volts. All my keyed on fuses 11.5 til she warms up and all my constant fuses 12.5 Was wondering if I can use the main stud on starter relay for constant voltage? Should be 12.5 volts. Pump harness is fused. Been running a toggle switch off the constant fuse on fuse box but sometimes forget to flip on when starting car and then realize no breaks backing up and then flip on. Rather than run direct to battery and looking obvious I figured starter post. Any thoughts on this set up? Thanks in advance
