I don't understand your use of the term "True Fuel injection system" Is there a fake one? If you are confused I have also enclosed the actual definition of fuel injection.
Typically, the only thing in common all fuel injection systems have is the lack of carburetion. There are two main functional principles of mixture formation systems for internal combustion engines:
internal mixture formation, and
external mixture formation. A fuel injection system that uses external mixture formation is called a
manifold injection system; there exist two types of manifold injection systems: multi-point injection (port injection), and single-point injection (throttle-body injection). Internal mixture formation systems can be separated into direct and indirect injection systems. There exist several different varieties of both direct and indirect injection systems; the most common internal mixture formation fuel injection system is the
common-rail injection system, a direct injection system.
The term electronic fuel injection refers to any fuel injection system having an engine control unit.
For the individuals question I offered another option for his ability to introduce fuel into his cars engine using an incredibly easy to install and very efficient and reliable system. I would encourage you to create a reply to this posts creator extolling the far superior benefits of a system that include how in a "true fuel injection installation, the injector nozzles would be in the intake runners near the mounting flange, angled at the port centerline, supplied higher fuel pressure, supplied by a fuel rail."
Oh Just my opinion of course.
