Here's a very important tuning item especially if running a bigger cam; Measure your intake manifold vacuum at idle with warm engine. What ever the reading is, make sure your power valve in the carb is set to open at least 1 "Hg lower. Big cams usually result in low manifold vacuum and if the power valve isn't the correct setting for low vacuum, it will hang open at idle and load up the engine with too much fuel. When that happens, you can have engine stalling at idle, fouled spark plugs and worse, a lean backfire through the carb when you transfer off-idle onto the main jets. So if your manifold vacuum is at 6 or 7 "Hg, you want your power valve to be set to open at approx. 5.5 to 6.5 "Hg. Holley power valves come stamped with the vacuum setting on them, and are available in ranges from 10.5 down to 4.5"Hg. Happy tuning.
