wierd cylinder compression
johnny ga
11:42 AM
vienna ga
i have a 318 bored 60 over crane cam each cylinder has a 10lb increase in pressure cyl 1and 2 the same 3and 4 the same5and 6 the same 7and 8 the same. late model 302 head. motor runs good.
So you are saying you have 30 psi difference between cylinders 1 & 8. That sounds on the verge of not good, but if it's running OK, it can be run longer, but I would venture to say that the power is down noticeably. Maybe the even distribution of cylinder pressure loss is making it run smoothly.
What are the numbers?
starting at 130 and going to 170 motor is fast when it the 72 challenger
Next step. Redo the test. Count 5 hits on the gauge each time. This time start the test on the cylinder where you finished the last test and work in reverse order.
Try doing 5 and see where it’s at. Then on the lower cylinders do 8 and see if it goes up. If it does u have bad valve guides and a bad valve job. Kim
