Here's what I was talking about. http://www.catalograck.com/ImgVDHR/KNE/66-1401.JPG
Yeah-yeah, quit rubbing it in lol. That hole in your hood is looking better all the time. I think I might pick up a K&N and try it with the Proform base. Then I will have boughten 3 air cleaners for 1 car.
Good to see you back on the forum Speedy. Everybody must be healthy again in your neck of the woods huh? I looked at the K&N also and like the extra flow through the top, but thier bases only drop 1.25" - the same as a Holley.
Hey H2E . . . here's a wild and crazy idea . . . just a thought . . .
What about changing it up and making it a Cool Air setup ? ? And you could place the filter like this ? ?
Just throwing the idea out there . . .
You already know I think outside the box . . . or in this case, inside a box ? ? ( smile )
That would solve my problem, but it is a little to modern looking for me - no offense.
Don't feel bad Joel, I ended up buying a couple myself. I have the K & N Extreme filter, filter lid and drop base on mine as well. I have a new Summit element top (doesn't fit K & N filter), and a new summit element filter (too tall) sitting in a box, collecting dust. I'm using a K & N Drop base.
P.S. June is right around the corner.
You will want to keep that 1/4" spacer, its a good insulator to keep fuel peculation at bay
Hey Will, not sure if RR's and Chargers have the same hood clearance but what kind of space do you have from the top of the stud to the bottom of the hood? Are you using a hood pad? I see great minds must think alike - we both mounted our coils the same way.
Going off the machinist puddy test, I got me a whopping 1.4" of clearance.
Joel,
Just got done measuring my base out. Keyser was being a little optimistic about their 1.75". I got 1.5", maybe a 1/32" over .5
I have the throttle return spring set up like yourself and had to do the same, or the springs would have been rubbing up against the bottom of the base. Anyways, IMO for maybe a tenth of an inch, don't think the Keyser would be worth $30 bucks to ya. Heck a little trimming on yours and you'd easily be where i'm at. One thing I will mention is just like the spectre and eddy filter lids, the K & N lid also pitches up a tad. Finding a nice flat one might give you another 1/4" or more. I would imagine you would need to trim down your carb bowl vents a little, which isn't a big deal.
This is one of the last purchase choices I have to make once I get my hood back on and fitted... I definitely know what thread I'm coming to now to help with my decision!
Thanks Will - you're the greatest! I thought about grinding the bottom flange of the base too. I think I should be able to get 1/8" off and still clear my throttle linkage. I'll make that decision once the Spectre arrives. Regardless, I wish there was more room under there.
I've got a real nice looking/brand new Holley air cleaner kit with a 1 1/4" drop sitting on my shelf that would look sweet on your car lol.
Which Holley kit is it? If it left you that tight I'm not sure I would have room for it either![]()
http://www.summitracing.com/parts/hly-120-102/overview/
This is the one I have. I wouldn't use it on a Charger with a RPM, but Will thought RR's had more room under the hood?
