looking good Hawk.......... im gonna bring you your air grabber door and battery tray maybe next weekend....... i got a lot going on, but will try to make time to pop in on you
So I got a proper, factory brake booster. Now it all fits like it should! Work this weekend has been slow going due to the cold (13F this AM), but little by little, and with lots of hot beverages, I'm getting it done.
The master cylinder brake lines needed some significant adjustment, but the brake system is in now. Except for bleeding the master cylinder and brakes later, it is all done! None of the brake lines touch or rub where they shouldn't, so I think we will be in good shape here.
I also got the gaskets for the hood mounted turn signals, so I mounted that unit on the car. To the best of my knowledge, my car did not come with hood mounted turn signals, but I really like them so they were added to the build!
Wow! Looking very nice and a ton of progress. I wonder though if it's possible to run the a/c hoses through the inner fender wall back by the firewall and along the top of the wheel well underneath and back in through the inner fender in front of the radiator support? Put rubber grommets in the holes. Even add a channel under there to run them in so stones etc don't damage them? I like what you have done and it looks sweet! Just thinking for mine in the future.
Envy bug biting hard man, that is some neatly done work and looks great!!!
She sure looks different then when you got her, I bet you are in a hurry for summer and at the same time enjoying getting ready, I sure know i would!!!
Thanks! She DOES look a lot different than when I got her, and yours will be there too. But we both have the same requirement to get the cars done: One step at a time - I'm just a couple of steps ahead of you!
Hawk
The brake booster looks good.
where did you get it?
how much $$?
I am considering doing power on my 70 4 dr sedan
were you able to return the wrong one?
Everything is just fantastic Hawk .. I am always prepared to wipe off the drool every time I check in to see your progress.
If it's possible I'm more and more impressed with each visit ! You are doing a top notch job with a car / color I love anyway![]()
