Major Milestones Today!
I had some major milestones today.  Since I got the wipers in, I was now able to get the dash in.  And since the dash was in, I was able to get the K-Member in too!  Wow, that's a lot, but it all kind of fell together.  There is, of course, LOTS of cleanup and wiring and hose routing, etc., but the engine and dash are off my garage floor and on the car where they belong!!!
Sorry for the picture dump, but here it goes:
I cleaned up wiring under the dash to prepare for installing the dash.
Dash installed in the car!  It was actually quite easy, as we just handed it in through the windshield.  The only issue with the dash is that my added-on fuse panel had a clearance issue with the heater box.  I thought it had enough room but knew it would be close.  I will have to improve this, but I'll save that work for another day...
Dash from outside the car.  Nice with some more black to contrast the green!
Then I figured I would get to the K-member and install that too. I won't upload TOO many pictures, but here are a few.  Installing an engine from the bottom with a lift is the way to go!  Very controlled, very easy (I did this part alone), and no risk of a heavy engine swinging around and damaging stuff...
Here is the underside of the car after it was installed.  Of course, I had to carefully check to be sure the car was still weighted properly on the lift (it was).
Here is a shot under the hood, you can better see now how the A/C will all fit with the heater hoses.  A little bit busy, but that's the best I could do here to minimize the A/C footprint.  Note that my air grabber vacuum can could no longer sit in its stock location, so I moved it to just above the A/C hoses.  This is close to its original position, and maybe it hides the hoses just a bit.  Note that the fuel pressure regulator and pressure sensors are hidden by the engine - this is what I wanted to minimize being able to see the fuel injection stuff.  I still have a lot of wiring cleanup here.  I plan to wire all the new wires together with factory dry electricians tape to make it look as factory as possible.  That will have to be for another day...
OK.  Now it is time for bed.  It has been a long day but I am excited!  Lots got done today!!!  :hello2:
