MoparMitch
- 12:46 PM
- Apr 12, 2011
- Friendship, Maryland
All looks awesome Hawk. If I bring my GTS seat stuff to Carlisle, will you do mine ?? JK
Man - This is exactly where my Bee stands. The dash, steering, wiring, clutch linkage and front brake plumbing. Looks awesome.
your Gaining!
a saying at the body and upholstery shop next door...
Yesterday I didn't know how to spell upolsterr'er and today I are one
I'm sure you gave your job more TLC than having anyone else doing it.
I was doing the same last week replacing the burlap and doing some repair on my 4 door.
the blister I got from the hog ring pliers is just about healed up.
I cheated when I put the new burlap down on the springs.
first the new burlap then laid the old burlap with the wire on top of the new and hog ringed both to the springs.
I've been using an old Kenmore sewing machine I bought from Good Will for a few dollars, for most of the sewing has been working fine.
One final update before the Superbowl starts.
First, I always push safety stuff, because things can go wrong in a hurry. Do I listen to myself? NO :iamwithstupid:
I was using steel wool on my headlight bezels when I realized that they were stainless. Why not polish them? Of course, I started without my gloves on and the bezel got caught and whipped around on to my hand. OUCH! Nothing really serious, but it hurts.
Folks, wear your protective gear- it only takes a second to get hurt...
OK, here are the results of the bezels - My car now has eyes!
Nice work on the Dynamat. Interesting what you said about wiping lacquer thinner on the roof. I sanded down the ceiling 'cause it was all surface rust and then covered with POR-15. I plan on installing the Dynamat too so I'll have to check on the surface prep before the install.
I think it's safe to say that your car is about as close to perfect as one can get... I'm have to admit that after reading your posts I say to myself " I want to do that!"If I would have done this car perfectly...
Hawk
Nice work! You're going to notice and really enjoy how much drivetrain & road noise that mat will eliminate. A real good addition. Install looks great!
I was not planning to Dynamat the trunk area, but just hope the dividing panel and rear seat would absorb the noise. I was thinking maybe to add some more noise reducing material to the panel or seat back if needed.
Any disagreements with this plan?
Thanks,
Hawk
I thought the same thing Hawk. I started to continue with the sound deadener into the trunk area, behind the rear seat brace, but then stopped and took it off again. I ended up putting the felt underlay onto the back of the divider board. Keeps the trunk area looking better too I think.
The red tool in the picture is a tool that you can pick up at the local home improvement store, it's a tool for installing the spline into the groove that holds the screening in place for your screens in your house.
Just go to the screen repair area and you should be able to easily find it. Looks like a great tool to have on hand for dynamat installation ! !
