Well.. bigger is better is the main response haha, no surprise there! Here's the thing, while bigger is better in most cases you also have to figure in Ohio weather............ Creating a big enough but not to big space means cheaper climate control. Bodywork in Ohio can be a nightmare with the humidity and a real pain in the freezing cold winters so heating and cooling is a big factor. Here's what I'm thinking right now, build the garage as if it were 2, the 1st would be a 24X24 with 2 bays only for parking cars and storing yard equipment (no heat or insulation or at least for now) the 2nd would be 32X32 with a 16 ceiling allowing the extensions to the trusses for more space and a second story for storage.
I think we think alike................ your the one doing all the crazy mods to your car too right haha? Yes the vertical aspect is the real trick, I've got a loft in my current garage and is unbelievably handy for storing body parts while restoring a car. Some good ideas there.
Love the upstairs steps! Hmmmmmmmmmmmm, I live on a hillside and it might be possible to make a ramp into the upstairs? Beautiful shop Hemi.
I also have 11 acres in the country with the only restriction of a 50 foot set back from the dirt road. I have 1480 feet of road frontage. I keep threatening to build a big garage but so far no dice from the misses. Still in one bay of a double garage. It's 12x 30.
As to your question...i suppose bigger is always better. I'd use your 24' trusses and go long...then add a cement pad about 12x24 in the middle with doors into the bigger space. Frame it up as storage and put your stuff in there like parts and equipment you don't always use. As usual you should try to be creative with the vertical aspect of your space. Make the building ceiling height high enough to install a post lift or rotisserie. Hanging hoods, fenders, door shells etc from the ceiling rafters frees up space below, hanging smaller parts on wall space does too. Good luck! As far as separate space for welding/fab and bodywork i would just buy some heavy mil thick plastic sheeting and hang it as an overlapping curtain to separate the spaces.
Here's mine. It's 28 x 44. I was limited to 1250sq ft since I'm in the city limits. If I were in your situation, a 30x60 would sure be nice. I put in an exterior entrance for the attic as I'm not getting any younger. It's 4' wide and is really nice when hauling up hoods and fenders.
