kjalltrac
Due to all the high taxes on everything here, everything are expensive as hell.
Just payed 6,5 $ / gallon of gas today.
I thought about buying a 6al, I already had the 6a on a shelf in the garage so I used it instead of the faulty orange box that came with the car.The biggest reason I run a 6AL ignition is the rev limit. Woulda saved your motor.
Only have about 8-8.3 CR and it likes 39-40 deg, don't like less than 20 deg initial.One comment, you're running 40* total timing. In my iron head motors with 11.5 to 13.0 CR I never ran above 38 all in at 1200 RPM. My 10.5 CR EDE RPM head 500" liked 36*. Just a thought.
Have you broke one? We run a stock cast crank to 850hp (9.55@142/3775lbs). Year 6, still going.If that has a cast crank your wasting your time its going to break leave well enough alone
