Darthomas
Had an annoying flange exhaust leak fixed at a custom exhaust shop.
I bought a new car cover to keep the dust off. One of the easiest upgrades ever.
Yup...it'll keep 'Cuda safe and dry for the rest of my life...!Good idea. BTW, a new roof is an expensive necessity that is often greatly under appreciated.
to all of you guys that do all or most of the work on your cars yourself! About all I can take credit for is driving 30 miles to go pick my car up from a friend (that does OUTSTANDING work) who has done the following work on my 69 Coronet 4 door:First of all, I would like to giveto all of you guys that do all or most of the work on your cars yourself! About all I can take credit for is driving 30 miles to go pick my car up from a friend (that does OUTSTANDING work) who has done the following work on my 69 Coronet 4 door:
Front Suspension and Steering:
Replace Inner, Outer Tie Rods and sleeves. Remove and replace upper control arm bushings. Remove and replace lower control arm bushings. Remove and replace upper and lower ball joints. Remove and replace upper and lower control arm limiting bumpers. Remove and replace strut bars and bushings. Remove and replace torsion bars and seals. Degreasing of all hardware and parts. Bleed and adjust front drums. Set front end height at 26” to wheel well opening ( approximately 1 inch lower that previous ). Grease all fittings. Pre alignment adjustment of TOE and steering wheel.
Rear Suspension:
Remove and replace real leaf springs. Remove and place bushings, spring shackles. Replace axle U-bolts.
Sway Bar:
Drill mounting holes in K-frame. Install K-member mounts and lower control arm mounts. Install sway bar with bushings ( greased with lubricant to avoid squeaks) . Lower car and tighten all connections with loaded suspension per instruction manual.
Transmission mount and O-ring leak:
Remove exhaust to access transmission cross member. Support tranny while removing cross member and mount. Degrease transmission housing, speedometer, mount and bolts. Remove and replace tranny mount. Tighten pan. Remove and replace speedometer gear seal. Drain and fill transmission.
Instrument Lights:
Trace short to dash lights. Diagnose faulty dimmer switch. Remove and replace dimmer switch after reworking and bench testing unit. Removal and replacement of instrument panel. Replacement of all instrument panel bulbs with new parts. Re lettering dash controls. Replacement of all fuses with correct amp rating fuses. Replace dome light bulb and ash tray bulb.
Carburetor Rebuild and Calibration:
Remove and replace carburetor. Rebuild and adjust all settings per factory manual: float level, accelerator pump and fast idle. Adjust timing and idle mixture by rpm and vacuum gauge method.
Driver door hinge:
Support door with padded door installer. Remove and replace interior panels and padding. Remove and replace hinge. Drill hinges to .38. Install brass bushings and pin. Adjust door.
