HT413
Semi Pro Bowler
As kiwi said up above, same thing happened to me and it turns out it was the fuel pump pushrod. If you have another pump, wouldn't hurt to try it out, but I'd say while you're in there, pull the pushrod and give it a look.
The carb loosing fuel from sitting is typically from evaporating, had that problem too. I just bought a phenolic spacer to insulate the carb, problem solved.You know, you bring up a point I've wondered about myself since I installed the Carter "hemi" fuel pump that Mancini sells:
http://www.manciniracing.com/cabheen5psis.html
I always wondered why the inlet and outlet on these is only 1/4" NPT.
For example, the Edelbrock pump (that looks just like the old Carter design) has 3/8" NPT inlet and outlet, yet is rated for 10gph less than the Carter is?
http://www.manciniracing.com/edmeperpmse6.html
I do have an almost new "regular" fuel pump sitting on the shelf I could try, but its' inlet and outlet sizes aren't so great, either - and it's not rated nearly as high on flow rate.
As an aside, this thing seems to drain the fuel bowls in the carb after just sitting a day or two also. Wonder if that's from evaporation or the pumps' check valve
not holding?
Could it be related?
Fuel line is all 3/8" - what the factory used on all 440 and hemi cars.Really hard to say from all the info given BUT!, what size is your Fuel Line (if stock? TOO Small), Sending Unit, Stock ? TOO Small!! what is the GPM on the Pump???
FYI i run All 7/16 Lines, AKA -8,
Better up grade ! running Lean could Toast your Motor !!
Ill post pics
Ok, but as I just posted in #37 above, the pushrod has been replaced. Thanks.As kiwi said up above, same thing happened to me and it turns out it was the fuel pump pushrod. If you have another pump, wouldn't hurt to try it out, but I'd say while you're in there, pull the pushrod and give it a look.
I have a 3/4" composite spacer on there now; it was necessary for the secondary linkage to clear the factory intake.The carb loosing fuel from sitting is typically from evaporating, had that problem too. I just bought a phenolic spacer to insulate the carb, problem solved.
I don't think to many carbs will just drain back to the tank even if there wasn't a check valve. The seat is usually bringing fuel in above the fuel level making it impossible for the fuel to just drain back.
Oh no, no worries at all. Just giving some background.Please don't take this the wrong way, but new does not mean it is working as it should... Start from the back and work forward..
Yep. Probably. All I can make sense of, too.I Think Fuel Pump!!, a 650 carb starving for gas ? and fuel gauge dropping like that with 3/8 line ??
I'll remove the pump and blow some compressed air back to the tank to make sure the new everything is still wide open.
I'll check the new pushrod at this time as well.
Finally, the only thing left is the pump itself. The brand new, expensive mofo pump that has been rock solid at 6.5 psi ....until now.![]()
Oh, no doubt I'm draining the bowls, since that's the final entry point for fuel before getting shot down the barrels of the carb - and the jetting seems to be ok, in the ballpark anyways.moparedtn-After reading all this,Im still thinking needle&essay on the floats. It's been a long time for me but I don't remember a bigger seat assy. for them as for the holleys. I still think ur draining the bowls. Or your pickup sock is collapsing?
