- 10:43 PM
- Oct 16, 2014
- Salisbury, Vermont
That doesn't look too bad....![]()
Interior.
Not terrible, there are a couple of patches on the passenger front but overall ok. I got a killer deal on 72 sq ft of dynamat extreme, so it led me to redoing the interior. My car is originally T7 bronze with white interior, white seats long gone before I got the car. Gonna keep it simple and do black seats for now but will eventually do a custom white interior when I get there.That doesn't look too bad....
Changed the master cylinder. Cleaned scotch guarded and touched up the missing paint from the old one leaking. Now to replace the exhaust sometime soon.
I meant the green pads I have a brain fart on the name. I used it to remove anything and clean the surface where the paint will stick. Maybe scotch bright. dang now I know someone reads what I write.Scotch guard on painted metal?
Interesting.
It would be more accurate to say customizing the factory harness. I Started with a complete 98 Ram and have it down to just the drivetrain related components in the harness. I have been slowly depinning the factory connectors and rebundling the remaining essential wires to go through the bulkhead behind the engine. The other side is going to 2 Bussman fuse/relay panels that replace the entire factory power distribution center and junction block. CAN communications are still functional, as it the entire Ram instrument cluster. There are a total of 30 wires that remain and will pass through those bulkhead connectors. The remaining connections will be used for things like the lights and wipers rather than the OEM bulkhead connector.
This is something I am going to have to do on my project. I'm using a complete 2006 Audi A6 sedan dash/console/interior in my 67 Coronet.Impressive- you could start a business that way!
