What did you do to your Mopar today?
I took mine to the track yesterday to test n tune to see how the new tires work. Times posted in racers hangout 12 second section.
Dropped the 8 3/4 got it all cleaned up today, still gotta pull the axles and carrier but good start
took the 300K out to a show today sadly I didn't place . But then again the following car took 2ND so competition was huge!
Off to a slow start but ended up being productive.
Needed to paint repair a section on the inner fender because it had sand in it and was easy to get dirty and a bitch to wipe clean. Also a spot on the bottom of the firewall that got scuffed and partially missed.
Couldn't find my scuff pads and couldn't seem to get the sand out until I got to 320 grit.
Then my pre-val wouldn't draw paint.
Finally found the scuff pads, and tried another pre-val head, and that one worked.
was nervous about blending paint but 3 out of four sides came out great and the other is a "B"- I'll take it.
Also wrapped the last wire harness clip.
Had way too much paint mixed up, so I painted the battery tray (at least six coats), all the bolts, one hood hinge (after hurriedly blasting it), and all the hood hinge bolts.
Mocked up fan and radiator.
I had noticed the rad sat a little funny. Found out it's an aftermarket replacement :(
Looks like a Mopar tank, but no numbers. one of the four bolt locations isn't even close and the other on that side makes it sit down to far.
Anyone know why the driver side mount is closer to the engine and the pass side is flat with the core support?
Paint patch is right behind/above fan in pic.
...and found out one of my heater hoses is original to the car- wow.
The one going under/around the compressor.
Just took the GTX out for about an hour ride, sun is shining and roads are clean and dry.
Sat.....Picked up 528 for the ride to my engine builder. Worked on the wagon a bit.
Sun.....Dropped off 528, and picked-up 496 for 67, had great Mexican food for lunch. 2 hours each way.
Today....Back and forth to the powder-coater for wagon parts. Installed the front shocks on the 67. Pkg'd some stuff going to Finland.
Put on powder coated bumper brackets no one will ever see.
Screwed with the dash lights and got them to work.
Laid the million pieces of carpet out (66 charger)
Tinypic was down, so here's a couple pics of what I was doing to the 67..........
Rebuilt the entire front-end, again.
Got the Super-Tricks and tires on the car........
Got the engine home.......
