Just curious as to what was stock rear gear in '62? You said you went to 3.23.
Positively! Something happened in the build. Not common, but it's too easy to make a simple mistake, and you get what you get.I'd take it to the shop. First check would be if it has any pressure.
Not positive, since I've never tried it...something like spinning like a top?
Years ago I did a friends 518. After a few years it wouldn't move. Tore it apart found nothing. Turned out it broke the converter. Don't know how on a stock FI 318, but it did.Removed the trans last night. Ran it up to the shop this morning. They started to tear it down while I was there and they found nothing. Everything looked good. The only thing that wasn't inspected was the valve body so he's doing that later today and will let me know what he finds tomorrow.
Think I'd make sure the line in the radiator is clear...removing the return line at the radiator. The supply line was dry.
Wonder if they went through it, or just slapped it on. After the fact, huh.The pressure valve was stuck and was just circulating fluid within the valve body.
Hell with the popcorn...time for a cold brew...cheers!Don't know about you guys but I'm just about out of popcorn!
